TPS voltage correct but still Code 22
Old Sep 5, 2014 | 10:05 PM
Teague's Avatar
Ok so I have a 1986 Iroc Z TPI 350. For last year or so I have been getting a code 22. I went out the other day and adjusted the TPS to the correct voltage (.54 at idle and 4.0 at WOT) But I am still getting a code 22. Am I missing something?
Old Sep 5, 2014 | 10:45 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: TPS voltage correct but still Code 22
You do not have an 86 350 TPI, so I must assume your engine management setup is the 305 TPI.
If you are getting the correct readings at the sensor, check if the same voltages are being returned to pin C13 on the ECM, the wire will be dark blue. If no, you have a wiring issue.
Old Sep 5, 2014 | 11:02 PM
Teague's Avatar
I will check that. Thanks
I did a engine swap a few years ago, I replaced the Prom, injectors, knock sensor and the ECS.
morrow
Jan 13, 2024 12:29 PM
GTAman
Sep 21, 2015 09:57 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
