anyone have bearing specifications?
Car: 91 G92 Z28
Axle/Gears: 342
I just got my 91 305 back from the machine shop today. I'm not sure what the main or rod bearing oil clearances should be. The shop gave me print-outs of all the specs, but that page was missing when I got home.
Here is what plastic-gauge measurements were:
Front to rear-
.0015 inch /.038 mm
.001 inch / .025 mm
.0015 inch / .038 mm
.0015 / .038
.002 / .051
Front to rear-
.0015 inch /.038 mm
.001 inch / .025 mm
.0015 / .038
.002 / .051
Re: anyone have bearing specifications?
Looks reasonable to me.
Remember, it's not a race engine, that'll be run cold with straight 40 weight in it, 10% diluted with bypass methanol; it'll be street driven with 5W30.
Why in the world are you spending all that money on a 305 short block?
Car: 91 G92 Z28
Axle/Gears: 342
I'm just looking for the spec numbers to make sure it's within tolerances. Do you have them?
Ugggh!!! The 305 comment is like hearing a broken record. But thanks. I'm not building a race car as you mentioned. The G92 TPI 305 is only a few horses shy of the 350 of the same vintage. It has a T5 which is questionable behind much more torque and hp than this engine has, and for once I've decided to keep a nice numbers matching, reliable, stock as possible club event car.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
From my 1987 FSM for 305ci (L98 can have 0.0035 max clearance).
Main Bearing Clearance (service):
Front: 0.001 - 0.0015
Intermediate: 0.001 - 0.0020
Rear: 0.0025 - 0.0030
Rod Bearing Clearance (service):
0.002 - 0.0030
0.002 - 0.0030
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
