87 trans am smokes when starting
Old Sep 7, 2014 | 12:18 PM
Gritz-n-Gravy's Avatar
Car: 1987 trans am
Engine: 305ci v8
Transmission: t5
Axle/Gears: 10 bolt 3.56
i recently bought a 87 trans am firebird 305 5-speed with 98k original miles and i noticed when i start the car it puffs out some white smoke that smells like oil. could this be the valve seals or piston rings? or something else?
Old Sep 7, 2014 | 01:30 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: 87 trans am smokes when starting
Yes, most likely the stem seals are dried up/brittle and broke up.
Old Sep 7, 2014 | 02:43 PM
Car: 1987 trans am
Engine: 305ci v8
Transmission: t5
im going to replace them myself but is the tpi going to be in the way?
Old Sep 7, 2014 | 03:10 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
No, the valve covers will come off with some finagling, you probably will have to take of the AIR diverter valve, there's a 10mm headed bolt to the left (firewall side) of the plastic box, then unsnap the plastic box and you'll find another 10mm headed bolt.
Then you can sorta pull it back out of the way.
Driverside is pretty painless.
bryan623
Mar 22, 2021 06:43 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
squiggy2
Aug 9, 2015 09:30 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
