Will this setup work?
Old Sep 10, 2014 | 04:21 PM
SMKN327's Avatar
Car: 87 Camaro Z/28
Engine: 327 SBC, 495/481 lift, Dem 625cfm
Transmission: B&M TH350 Stage 2
Axle/Gears: 3.90
I have a 327 bored .30 over, 495/481 competition cams camshaft and a new street demon 625 cfm carburetor, approx. 365 hp. I was running a stock 700r4 with stock stall, and stock 2.73 gears behind it that was just spinning, wouldn't put the power down, at times it would "go" and then let up like it's guts were just spinning. So I got a summit fathers day special on a new B&M TH350 for $650, got a B&M Holeshot 2500 stall converter. Motive Gear 3.90 performance gears for the rearend. In the shop as we speak. Chomping at the bit to get it back. Will this setup work? Or is it a bust. Whatcha think?
Old Sep 10, 2014 | 04:25 PM
SMKN327's Avatar
Car: 87 Camaro Z/28
Axle/Gears: 3.90
Re: Will this setup work?
Sorry, car is an 87 Z28 Sport Coupe
Old Sep 10, 2014 | 05:03 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You're not going to like long trips
But Ya, I'd say the stall should help you get into the powerband and the 3.90's should keep you there with your foot to the floor.
Thinking you may be investing in tires quite often
Terrell351
Jun 13, 2021 01:13 PM
Eric-86sc
Apr 3, 2016 03:52 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Street Lethal
Aug 13, 2015 08:28 PM
