Is my cam too small?
Old Sep 10, 2014 | 05:08 PM
DanielRicany's Avatar
Hey guys. I have a 350 with a Miniram, AFR 195 Eliminator Heads, Hooker 1 3/4" Longtube Headers, 1.6 Roller Rockers, 58 MM Power Products Throttle Body, MSD 6AL2 igntion box, D.U.I. distributor, Corsa true dual 2.5" exhaust with h pipe, and some other small miscellaneous modifications. I also have 3.75s in the rear.
This is a 1985 Corvette.
My current camshaft is TPiS' flat tappet version of the ZZ409 roller cam.
Again this is a FLAT TAPPET camshaft.
The specs of this camshaft are 224*/224*duration @ 0.050", 0.528"/0.528" valve lift with 1.6 roller rockers, and 112* LSA.
I only bring this car up to 6000 RPM MAX.
I personally don't think that the car has as much power as it should. I haven't dynoed it yet.
So this brings me to my next question. Is this a mismatched combination? Is the Miniram shining right as the cam is falling off?
Thanks.
Old Sep 11, 2014 | 04:20 PM
Re: Is my cam too small?
Nobody knows?
Old Sep 17, 2014 | 07:53 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
No, for 6000 RPM max, it's definitely not too small.
junkcltr
Aug 2, 2019 11:12 PM
Mickeyruder
Sep 2, 2015 02:45 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
camaro71633
Sep 1, 2015 10:24 AM
