305 rebuild need cam choice
Old Sep 10, 2014 | 05:35 PM
jmat2407's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: BW 3.23
Ok so picked up an 86 Camaro. It had a 305 with a tbi intake and a edelbrock 1405 carb sitting on top. I pulled the heads to get checked for cracks or leaks and theyre good to go.
Im not looking to build a high performance engine. This is a simple rebuild all I want is a dependable new engine that will get the car up and down the road for the next 2 or 3 years while I rebuild the rest of the car and eventual engine swap.
So with that said I will be running..
305 NON roller block getting bored .030 over.
-601 casting heads just checked and resurfaced
edelbrock performer intake
edelbrock 1405 600cfm carb
Stock the engine had dished pistons. Considering spending the extra coin on flat tops. ( all the rebuild kits come with dished it seems). Not sure how high this would make the CR tho.
Needing help on a cam selection. Not sure what the stock cam numbers are. I havnt jacked the rear end up yet to see whats in the car now but I will probly run a 3.42 rear end and the stock 700r4 trans.
Old Sep 10, 2014 | 06:07 PM
jmat2407's Avatar
Engine: 5.7 TPI
Axle/Gears: BW 3.23
Re: 305 rebuild need cam choice
Im thinking maybe the comp cams xe262H perhaps?
Old Sep 10, 2014 | 06:46 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
edit:
Ooops. sorry. see that the heads have been worked on, so my original reply does no good since the block is in the shop as well.
Jake_92RS
Jan 28, 2020 10:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
