Question
Old Sep 15, 2014 | 05:15 PM
Aaron41's Avatar
Question
Ok fellas jus got a 1986 FireBird TransAm, what are the two sensors on the rear of the block on both sides. I knw the sensor in front is the temperature sensor switch for fan, are they both oil pressure sensors ?
Old Sep 15, 2014 | 06:15 PM
Re: Question
Not sure what sensors you're talking about.
There's a knock sensor in the pass side coolant drain hole; at the exact front-to-rear center of the block, just in front of the front end of the starter.
There may be an oil pressure sending unit (not really a "sensor") above the oil filter.
There's a fan switch (again, not really a "sensor") between the #6 & #8 spark plugs in some cars, pass side head; not in the block, but hey...
There's a temp gauge sending unit (yet another "not really a sensor") between the #1 & #3 plugs, same hole as the fan switch except the other head.
Which ones are you talking about?
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
