valve spring dampers?
Old Sep 25, 2014 | 03:17 AM
thatoneguy5x's Avatar
Car: camaro
Engine: 3.1
Transmission: auto
are they needed?
they are kind of a pain.
I don't have any crazy mods or making crazy power. its just a daily driver 3.1.
Old Sep 25, 2014 | 06:15 AM
Re: valve spring dampers?
There are springs that are made to work without them. If you have those, then you don't need them.
OTOH if you're talking about just taking them out of your stock springs, that's a different matter. Stock springs are limp-membered enough already without being further weakened by removing something that stabilizes them.
Not sure how they could ever be "kind of a pain"; they mostly just hang out in the middle of the springs under the valve covers untouched for a hundred thousand miles or whatever. Pretty much out of sight out of mind.
Old Sep 25, 2014 | 03:58 PM
Car: camaro
Engine: 3.1
Transmission: auto
I should've specified that im in the process of replacing my valve stem seals. the dampers don't let my spring compressor get a good hold of the spring. i'll leave them as is then. thanks for the reply
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
