Timing advice Pleas
Old Sep 26, 2014 | 08:06 PM
MikeMN's Avatar
Car: 1988 Trans Am GTA and 1979 10th Anv
Timing advice Pleas
I need timing help Pleas, I have a 1988 GTA 5.7 and I just installed a new distributor, can someone pleas explain how I need to adjust the timing and what degree it needs to be set at.........?
Old Sep 27, 2014 | 08:50 PM
MikeMN's Avatar
Re: Timing advice Pleas
Thanks for all the Help...........
Old Sep 28, 2014 | 11:56 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Missed this one
You need to locate the EST bypass connector, on my car it's sorta laying on the pass side fenderwell, believe it's a tan/black wire (single wire connector)
Unplug it, and set your base timing to 6* BTDC, shut the car off, plug the connector back in...you should be good to go!
Old Sep 28, 2014 | 02:00 PM
MikeMN's Avatar
Thank you........
ZMWojnar
Brakes
May 12, 2019 10:43 PM
justin57
Aug 20, 2015 07:05 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
