91 TA idling problem (NEED HELP)
Old Oct 1, 2014 | 09:06 AM
empire5150's Avatar
Car: 1998 TA
Hello all. I just bought a 1991 Trans Am with a 305 TPI automatic. It has been sitting for almost a year. It runs almost perfectly when you just barely touch the gas but if you let off completely it does not want to idle. It runs very rough and almost immediately stalls. If you can get it into gear without stalling and drive it down the road it runs fine till you stop at a light or stop sign as it will stall if you don't do a "brakestand" Can someone please help? Where do I start with this problem? Also oddly enough theres no check engine light on at the moment. Thanks so much!
Old Oct 1, 2014 | 09:14 AM
z28yourstang's Avatar
Car: 1986 z28
Engine: 350 hsr
Transmission: probuilt 700r4/edge 2800
Axle/Gears: stock 4th gen 3.23
Re: 91 TA idling problem (NEED HELP)
Start with checking sensors such as IAC,TPS, and CTS.
Also check for vac leaks
Old Oct 1, 2014 | 09:26 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Welcome Empire........follow this to a T
https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
It should help tremendously!
Old Oct 1, 2014 | 09:44 AM
empire5150's Avatar
Car: 1998 TA
Thanks soooo much for the help. I will give it a try!
Old Oct 1, 2014 | 09:48 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
your welcome. When you take out the IAC, be sure to clean the passage in the TB and clean it all up.
Old Oct 1, 2014 | 10:04 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Old Oct 1, 2014 | 10:17 AM
empire5150's Avatar
Car: 1998 TA
Thanks once again! I will definitely try this!
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
