350 Firing on only 4 cyclinders (2 per side)
Old Oct 10, 2014 | 11:48 AM
214jay's Avatar
Car: 1989 Pontiac Firebird Formula 350
Hello.
I have finally got my engine back together after replacing upper gaskets and TPS.
I set the no.1 cylinder to TDC (timing mark to '0' after no.1 intake valve has closed and before exhaust valve opens). All plug leads are correct, have double checked this. At first it fires up but dies instantly so I unplugged the tan wire and it fires, runs rough, but only firing on two cylinders per side.
Have tried turning dizzy slightly to see if that affects it but not much difference.
Any ideas where to start? It was firing on all cylinders a few days ago before HG change.
Jay
EDIT: Car is an 89 Firebird Formula 350 TPI
Old Oct 11, 2014 | 03:04 AM
214jay's Avatar
Re: 350 Firing on only 4 cyclinders (2 per side)
Has anyone got any ideas on this?
Old Oct 12, 2014 | 02:18 PM
214jay's Avatar
Thought I would post my solution to this for anyone who stumbles across it. Turns out I had tightened valve lash too much which was causing me to lose compression! Re-done valve lashing and it fires up a treat now.
92camaroJoe
Jul 29, 2023 07:57 PM
Jake_92RS
Jan 28, 2020 10:37 PM
TheExaminer
Aug 19, 2015 10:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
