Head Cleaning
Old Oct 12, 2014 | 06:17 PM
herders's Avatar
Car: 1986 Firebird
Engine: V8 305
Head Cleaning
Hey All,
Is cleaning a head properly, to get all the carbon and stuff out something that can be done at home, or should it go to company for cleaning? if at home what kind of tools, bits should one use.
Old Oct 12, 2014 | 06:23 PM
Damon's Avatar
Re: Head Cleaning
It's tough to scrub in all the little nooks and crannies. Get off most of the junk as best you can first. Then it's time for a good spray down with Easy Off oven cleaner. You know- the stuff that cleans off greasy carboned-up junk out of your oven? Works the same on greasy carboned-up junk clinging to your cylinder heads, too. Won't hurt aluminum that I'm aware of, having used it to clean the crud off (aluminum) piston faces and ringlands, but I've never actually done it on aluminum cylinder heads.
Old Oct 12, 2014 | 06:55 PM
Re: Head Cleaning
Makes a big mess to do it at home, and doesn't do a very thorough job usually.
For as little as it costs, probably something better left to the shop.
Old Oct 12, 2014 | 07:08 PM
herders's Avatar
Car: 1986 Firebird
Engine: V8 305
Re: Head Cleaning
What would the average cost be to do 2 heads??
Thanks for the replies.
Old Oct 12, 2014 | 07:38 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: Head Cleaning
My machine shop charges $50 per pair to hot tank clean bare heads. Not sure if price will be any different if fully assembled, never had assembled heads that I needed to have clean that I didn't rebuild.
Bubbajones_ya
Aug 28, 2015 02:17 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
mdtoren
Aug 23, 2015 12:52 PM
qz6lwp
Aug 20, 2015 08:10 PM
mdtoren
Aug 16, 2015 05:45 PM
