melted pcv hose to manifold
Old Oct 15, 2014 | 08:59 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Replaced my pcv yesterday which caused a serious vacuum leak. Checked and the hose had cracke . Went to pull off the hose and the part that connects to the block and found it melted on there. So I bought a hose just bigger than the new pcv hose and fit it snuggly over the one on the engine and the new hose as a quick but successful fix any tips on removing the hose still on the engine? I used vice grips and pliers and only pulled apart little bits
Old Oct 16, 2014 | 02:29 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Re: melted pcv hose to manifold
Try to get in there with a pocket knife and cut it off.
Old Oct 16, 2014 | 05:53 PM
Damon's Avatar
What the heck could be so hot on the top of the engine that it welded a PCV hose to itself?
Inquiring minds want to know! (Pic?)
FYI- Almost all GM stuff uses a nothing-special 3/8" hose size.
db057
Jan 10, 2020 08:55 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
sleprock
Sep 24, 2015 04:33 PM
st.evel07
Sep 19, 2015 09:24 PM
