91 z28 fuel pump issue
Old Oct 17, 2014 | 07:13 PM
jgracing9's Avatar
hi i have a 91 z28 with a 305 tpi, when i bought the car the fuel pump started to whine. so i bought a new one along with strainer and fuel filter, installed everything and after 2 days the new fuel pump starts to whine (ac delco pump). i check the evap system and its working. when i take the gas cap off NO air comes out or hissing nosie. so its dosnt seem its a pressure issue. btw the car has a bad egr valve and runs alittle rich. i did valve seals on it and adjusted the valves. i have 2 injectors that read 14volts and 6 that read between 9-12 volts.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
