Two cents
Old Nov 7, 2014 | 09:23 PM
Crudsturbo's Avatar
Two cents
Well I had made some threads about a no start issue I was having and had a few responses out of over 2k views. It seems like people only use this site to get help for themselves although there are the dedicated few that do a lot to help. Now that mine is running again and I do consider myself a pretty good mechanic I will be helping as often as I can. Mine had a bad ecm and the gas ruined from sitting as well as the fuel pump, strainer, etc. SO changed all and even discovered someone made a fuel pump door but thank them because at least it wasn't a hack job and they used steel line compression fittings. Also want to thank the few that did reply and cant wait to have my baby back as my daily driver.
Old Nov 7, 2014 | 10:33 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Two cents
Sorry to hear about your expearance concerning help on the site.
I've been here for 8 years now and have built a wreack into FINALY a dependable DD using this site.
In return I use what Ive learnd building my project to help others.
A lot of times its over my head so I move on.
I'm glad to hear you worked out the problems.
Old Nov 7, 2014 | 10:47 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Two cents
Ditto
Old Nov 8, 2014 | 07:06 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Two cents
it's kinda like old school hot rodding. when you didnt know something, you asked a fellow gearhead. and when the oportunity to help other arrives, it's freely given back.
ohohblita
Nov 7, 2002 03:35 PM
Andy89RS
Southern California Area
May 15, 2002 11:23 PM
B4Ctom1
May 14, 2002 08:11 AM
fast_broker
Sep 26, 2001 11:27 PM
DeathZ
Pacific Northwest Region
May 25, 2001 03:39 AM
