89 IROC pass side injectors get no electricity
Old Nov 9, 2014 | 09:27 PM
cdiedrick's Avatar
Car: 89 IROC
Ok my 89 TPI IROC runs bad and starts hard. Every plug wire gets spark, so I started pulling injector wires and the pass side seems dead. What do I do now? The care was outside and I know mice got to it, but I don't see anything obvious.
Thanks!
Old Nov 10, 2014 | 06:23 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: 89 IROC pass side injectors get no electricity
Thanks!
First thing you do is , get a 12V automotive test light and make sure there is power on both sides of the fuses marked "INJ 1" and "INJ 2" with the key in the on position . If there IS power on both sides of both fuses , then you must inspect the harness and find out where the mice chewed the wires apart . Remember , the ECM switches the ground side of the injectors and there is only the ignition switch and the two injector fuses in the positive side of the circuit . With one set of injectors having power , that would indicate either a likely fuse or open wiring fault .
Good Luck with it
armybyrd
Dec 5, 2015 09:22 AM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
wruiz
Aug 11, 2015 02:59 PM
3rdgenparts
Aug 5, 2015 11:57 PM
