Crank but no start unless throttle down
Old Nov 11, 2014 | 08:07 AM
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
I can start it with gas pedal down but will die immediately as soon as I let go
Fuel pressure at 40 psi
Inj ohm at 13 and are getting power at the connector plug
Getting spark to plugs checked by grounding each one however all plugs back so clearly getting fuel
Timing at tdc at the moment
New cap coil and rotor
Icm checked out good
Pickup coil had resistance at the plug connector can't recall value though (400-700)
Vats disabled thru chip and tunerpro shows all my sensors working when I keep it running
And no vacuum leaks I'm aware of
This happened after I changed my intake gaskets and installed a clutch kit and flywheel as well...I started it up at the time and let it idle for about 5 min then just died and hasn't started since. My last dreaded option is to check compression but was hoping for any other suggestions? Thanks
Old Nov 11, 2014 | 10:55 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Crank but no start unless throttle down
Originally Posted by maks10
I can start it with gas pedal down but will die immediately as soon as I let go..............all plugs back so clearly getting fuel..................
Maybe , way too much fuel ?
As you likely know , flooring the pedal puts the ECM into "clear flood" mode and shuts OFF the injectors . If it will only start with the pedal all the way down , and die the second you release the pedal I'd check for either a failed fuel pressure regulator or one or more stuck open injectors . Either of which could have coincidentally happened during the gasket change .
To change the gaskets , you had to take apart the fuel supply and return lines , yes ? This may have allowed particles of contamination to make it to the injectors and hang one or more open ?
Have you checked the vacuum line from the manifold to the regulator for the presence of raw fuel ?
Old Nov 11, 2014 | 11:04 AM
maks10's Avatar
Car: 1990 Trans Am
Thanks for reply the raw fuel smell is present but no actual fuel In line....plus it holds pressure at shut down as welI ...read about the injectors shutting off when throttle is down which explains start up but good point on contaminates in fuel line which ultimately could of clogged injectors ..... I guess I could swap injectors and see thanks for the info!!!
Old Nov 17, 2014 | 07:24 PM
maks10's Avatar
Car: 1990 Trans Am
Long story short:
TIMING!!!!! I was like 8 deg retard
I bumped the idle screw up enough to keep it alive and checked the timing and I was waaayy off
never had this happen before, usually get TDC and Im good to go...somehow missed this...sorry for the extra thread...hope this helps someone in the future as many other similar threads have had this result.
Orr89RocZ
Apr 25, 2016 08:28 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
perZ
Aug 15, 2015 01:17 PM
