Just need some verification
Old Nov 16, 2014 | 07:31 PM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
On my 350 TPI, AC Delco gives the same p/n for both the ATS, (air temp sensor mounted under the plenum), and CTS, (Coolant temp sensor mounted in the front of the intake). Is this correct ?
Old Nov 16, 2014 | 07:38 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Just need some verification
its the same thermistor, IIRC 85 was the only exception
Old Nov 17, 2014 | 07:54 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
You're back!!
Old Nov 18, 2014 | 04:42 AM
Engine: Lb9
Transmission: M20
Originally Posted by stealtht/a
You're back!!
I'm trying to stop in more often
gixxer92
Sep 1, 2015 04:32 PM
91RS_Charlotte
May 19, 2010 07:02 AM
Duts87ss
Jan 4, 2009 04:47 PM
BDR
May 24, 2007 11:12 AM
breesmom
Jun 15, 2006 07:03 PM
