i'm in trouble, called out a 5.0 GT with my 305.
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
http://ls1tech.com/forums/street-rac...her-5-0-s.html
lol
time to start planning build I guess. I ordered an HSR. the TPI has got to go!
so far i'm thinking
TFS 175's
ported HSR
22lb injectors
this lunati cam with 1.6 roller rockers
possibly considering going .030 over on the pistons with flat tops to get my static compression over 10:1 for the aluminum heads.
any other thoughts? has to remain very streeable, no F\I or N2O. no race gas. has to stay stock-ish cubes.
lol
so far i'm thinking
TFS 175's
ported HSR
22lb injectors
Hydraulic Roller Cam. Fair idle, great low to mid range power for daily usage. Works well with tune port injection.
•Advertised Duration (Intake/Exhaust): 276/286
•Duration @.050" (Intake/Exhaust): 218/228
•Gross Valve Lift (Intake/Exhaust): .503"/.503"
•Lobe Seperation: 112
•Intake Center Line: 108
•RPM Range: 1800-5800
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Re: i'm in trouble, called out a 5.0 GT with my 305.
with the TFS heads i'm thinking that the cam will need at least a 10* split.
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Ouch. You're going to get the hurt-on put down on you with that little 305. Ford 302 > Chevrolet 305 any day of the week.
Engine: 4++,350 & 305 CIs
Yeah, its not hard or costly to do a fox car. Sadly, I predict a hurting coming from the fox camp.
Unless they don't know what they are doing.
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
doing it with a 350 would simply too easy. that's why i'm going with a 305.
Car: 89 IrocZ
Engine: L98-ish
So you'll dump all that money into a 305 to "try" and beat a 302 ....and if ya don't?
Slap to the head, shoulda had a V8!
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
dont build a 305, waste of money! get a 350 you won't regret it
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
You must have some slowpokes over by you, haha. Most of us (smart) Ford guys have long ditched the 5.0 in favor of the 351. I imagine you'll probably get some of that. 347's are also common because they are cheap to build.
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
no more 305\350 nonsense. I have my LS1. why build a 350 if I have an ls1?
point is to build the best 305 that I can.
Car: 89 Firebird
Engine: 355 TBI
Dump the 305 and build up a 350 or your feelings will be hurt. No doubt. Unless the Fox car is a stocker.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
I hate to say it, but the fox body is about perfect for a drag car. "built ford tough with Chevrolet stuff!!!!"
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Gears would help a bit.
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Let me hide a 100 shot on it.......
Seriously. I have been through these cars more than I like to admit.......
You can do NOS if your careful. Under the intake and out the back of the blocks china wall if you use a wet kit.
Dry kit, stick it in front of the air box unseen. Hide the bottle in the dash.
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
nitrous is not an option for me.
my goal is to build the best N\A 305 that I can. if all out SBC power is what I wanted I wouldn't even bother with a 4" bore. I would go right to a 4.125.
Car: 89 IrocZ
Engine: L98-ish
Starting to think your whole post is well beyond guys sitting around talking about who has a "bigger cam".
Cough...cough...
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Well.........
If you are getting a HSR, go bigger cam and bigger trick flows...
LTs, 180-190cc heads and 525ish lift cam, will be a big wake up.
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
like I said if all out performance were the goal I wouldn't even bother with a 350.
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
that's why I was going to use the TFS 175's, they run a 1.94 valve and still flow pretty good. likely plenty enough for a 305.
Car: 1983 G20 Chevy
Transmission: 4L60
has anyone ever measured max valve lift with 2.02 valves on a 305 with a .060 over bore? they're pretty much useless on a stock bore and max out around .450 lift
I would recomeend running a fairly tight LSA cam in the thing with a modest duration and roughly equal intake/exhaust duration and lift. The Edelbrock heads flow well enough on the exhaust side they really don't need the split.
If you are doing your own tuning and serious about making power from the valve limited, small cube engine you need a fairly aggressive hydraulic roller with roughly 276/276 @ .006, 224/224 @ .050, .565/.565" lift w 1.6:1 rocker, 108* ICL, and advanced 4* on a 104* ICL. (That is a Comp XFI 268 exhaust lobe on both intake and exhaust ground on a 108* LSA core ground 4* advanced) With 60* of overlap and the tight LSA she will have a nice thumpy idle, but have good off-idle and midrange torque that keeps pulling through the RPM band. You could shift this cam at 6,200-6,500 rpm in a 305 with those heads.
With the setup and cam above and 5.7" rods it would end up around 7.8:1 dynamic compression ratio and should be good to go on pump fuel.
Car: 1983 G20 Chevy
Transmission: 4L60
lol
so far i'm thinking
TFS 175's
ported HSR
22lb injectors
lol
so far i'm thinking
TFS 175's
ported HSR
22lb injectors
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
I would run the Edelbrock Etec 170s over the Trickflows. I have seen far better numbers from the Edelbrock Etecs. The chambers are a little larger, but nothing that could not be machined smaller. Flat mill them down to 60cc, use a flat top piston with 6cc worth of valve relief, a .038" compressed head gasket, and a zero decked block. With a stock bore you would be 9.45:1, .030" over 9.57:1 and .040" over 9.62:1, perfect for pump gas.
I like the idea of a tighter LSA on the 305 but tuners do not. will 7.8 dynamic compression be enough? I was thinking about pushing it up closer to 8.5:1 on pump fuel.
does anyone have the flow specs of the edelbrocks vs the trick flows? I could get the compression up a little further by doing a .060 bore. it will also help it breathe better.
Y so low on the compression? If you have aluminum heads, get it up to 11-1 or so if you can.
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
narrowed it down to either hooker or dougs headers. they're supposed to work with the T5.
Within your parameters, this is what I'd do:
First off ditch the notion that you're not running the jug. He will probably be running the jug, so hide yours and let him have it when he's not expecting it. Cheating in grudge racing=getting caught. A buck fifty worth of spray will do a lot for you.
You should run 4.10s for gearing, or 3.73s minimally. You're going to want them for the cam you should run. That's not a terrible cam, but I would end up with something like this. http://www.summitracing.com/parts/hr...make/chevrolet The narrower LSA will make it have more average power, which is what you're going to be looking for. Stall speed I'd be looking for something like a 3500 (CALL A PRO) in order to make this combo work effectively.
Head gaskets, I'd be looking at some .027 Cometics with a small bore diameter, if you can do that. You may have to run 350 gaskets, at that point get something with say a 4.030 bore. You'll be ~10:1 flat if you have a 6CCs worth of valve reliefs in the pistons, and may want to shave a CC or two off the heads just to take care of incidental losses in compression.
Bottom end, a 335 would be fun but if you're wanting to stay stock stroke I'd probably go with a decent set of forged pistons and some capscrew rods like Eagle's I-beams. That will shed considerable rotating weight. I would also employ a good pan, and good oil control in the pan (windage tray) if it's not built in. You're actually going to try and rev this beast may as well optimize it for that.
The HSR should be pretty decent. Based on the CSA, you're going to be revving to 6800 or so to optimize for the runner length you have. I would want a 2" spacer for it to move the power band down some where the intake is more relevant. Without it, the engine will probably be done before the intake is. Not to say it won't make good power earlier.
Lastly, the heads themselves may need work to run the lift you should run. They have good flow potential out of the box, so I don't think that's going to be an issue. I would be conscious of the lift limitations and try to run the cam above with 1.6es, beehive springs/retainers and whatever tricks you need to get higher lift.
Headers/full exhaust are going to be a requirement. 2.25 would probably do, but I wouldn't be afraid of 2.5" true duals along with 1.625 Primary long tubes. They'll make great power although you could be near their limitations at higher RPMs.
Car wise, I would want slicks or DRs if you intend on hooking this. With the right stall and gears she should roast tires. I would also want SFCs and whatever it takes to actually get the car to hook. There's a huge amount of gain in the 60 foot, and you need to find it to make up for the lighter weight of a fox.
Car: 83 Z28/L69
Engine: L69 305H.O.
Transmission: 6spd T56
Axle/Gears: 4.10 LS 4th Gen
I'm more worried about the T5 holding up, without a little work.
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
i'm going to get 4.10 gears. wont be to cheap becuz 9 bolt.
also comsidering stepping up to a cc503 cam. I need this thing to rev.
Sorry, didn't see the T5 part. If you're afraid of breaking it, I doubt doing this is a good idea. The willingness to beat on it some is likely going to be a big differentiation. The 305 is a good cam, and should be stout in a 305 with the HSR to back it up.
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
i'm not afraid of breaking the t5. if it breaks, it breaks.
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
I've narrowed the 2 cam choices down to the cc503 and the 280 XFI.
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
where's the best place to get a custom mail order chip from?
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Wow I just realized the one thing tbi has better over tpi is flash tuning........
Car: 1983 G20 Chevy
Transmission: 4L60
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Car: 88 Chimera
Engine: 1994 LO5 5.7L
Axle/Gears: 2.73...?
Have you done all the weight reduction mods?
The less mass you have to move means you can faster quicker.
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
no weight reduction at all yet. that's the stock weight of the car.
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
That video with the camaro beating the mustang, the camaro is a G92 optioned 5 speed... I forget the code for Firebird... but the later 90 and up MAP stock ones beat the stock mustangs...
Mustangs of that era had 225 hp the G92 and so had 230 but 70 more ft.lbs. of torque...
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
if any other 80's cars want to play, follow the link in the OP and read the rules.
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
