SHP block - 1pc vs 2pc RMS
Old Nov 22, 2014 | 09:52 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I am trying to decide which block is better for me.
I am currently building a 400sbc (330817) 2bolt engine right now. I need this to run for one more year and then upgrade to a SHP block for next season.
I am trying to potentially use some of the same parts to carry over to the SHP block.(valve train)
Some of the benefits of the 1 pc rms is that I can use an OE roller cam and lifters. And potentially better sealing of the rear main.
http://www.summitracing.com/int/part...211l/overview/
A roller cam set up is about $500
Some benefits of the 2pc RMS is slightly cheaper.
http://www.summitracing.com/int/part...1211/overview/
A retro roller cam set up is about $825 for cam and lifters
Any more insight that I am missing?
Old Nov 22, 2014 | 11:45 AM
Re: SHP block - 1pc vs 2pc RMS
A certain amount can be found here:
http://www.dartheads.com/products/sh...all-block.html
Including "Provisions for OE stock roller lifters and cams", applicable to the whole product line.
Old Nov 25, 2014 | 01:33 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
If you plan to re-use the crankshaft that will dictate if a 2 or 1 pc rear main is needed on the future SHP block
It will also determine the journal size of the future block as well.
SO if you plan to re-use the 400 crank from your current 400 build the future SHP block can only be 2 pc rear main with 400 main journals.
WTH are you going to race now? it's almost December next season starts in 5 months ! or do you mean 2017?
Old Nov 25, 2014 | 01:42 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Shp has roller cam provisions already. Dont matter what rear main.
If you buy new crank then just get 2 pc, more options available that way.
Old Nov 25, 2014 | 01:46 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Right now I am rebuilding a stock 400sbc.(cast dish pistons, stock 5.565 rods and 3.75 stock crank) 9.2-1 compression, afr195, LT1 intake, 1 7/8 LT with hopefully a 150hp shot of nitrous.
I am going to run this engine for the 2015 season.
Then start assembling the SHP 400 block a year from now. Still deciding on a 406/414/421 cubes. Fully forged rotating assembly
AFR 195 for now, then for 2017 go with AFR227.
By that time I'll run a carb and different nitrous set-up, and hopefully roller cam of somesort(solid or hyd)
I will not use any of the stock rotating assembly(just possibly the valvetrain if it transfers over)
Old Nov 25, 2014 | 01:50 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
So you can get a 2 piece RMS with the ability to run OE roller cam?
So you would have to use the "spider" , or can that handle big HP?
I'm trying to get away from using the retro roller lifter, lots more $
Old Nov 25, 2014 | 02:14 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Thats what i have now. 2 pc block and oem roller stuff. Well i had spider but recently went link bar lifters but still use 87-99 style step nose cam, same timing chain and cover, same retaining plate for cam.
I am one of the highest hp numbers that i know of running thru the shp block...its a very stout piece
Hopefully carl sees this thread from cnc blocks northeast
Old Nov 25, 2014 | 02:26 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
At which point did you switch to the link bars?
Also, what is the part number of the OE roller lifter that you used?
Solid or hyd?
Old Nov 25, 2014 | 05:55 PM
HINKSON AUTO's Avatar
Solid or hyd?
Stock dog bone lifters with a .700 wheel are not as dependable as a tie bar lifter with a .750 wheel.
Old Nov 25, 2014 | 09:34 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
So at what point should a person switch to the link bar set up?
When using big lift cam?
Higher rpm?
Better geometry?
What about the PRO shp block? with the BBC lifter bore. Why is that set up better?
Old Nov 25, 2014 | 10:03 PM
Higher rpm?
Better geometry?
With cams over 230 degrees duration go to a better lifter one made out of better material and a bigger wheel.
BBC's lifters are only a .843 lifter bore same as the SBC,
The Dart SHP Pro block has .904 lifter bores and uses a BBC cam tunnel.
Anytime you can go to a bigger base circle cam = smoother valve action better profile, I machine a lot of blocks for 55MM cam cores which seems pretty popular now a days SBC, BBC and SBF.
.904 lifters, Bigger lifter and just about all .904 lifters are pressure fed, Bigger wheel = less revolutions around the lobe. Bigger body = stronger lifter. Bigger wheel = less pressure angle.
Going to a .904 lifter is very common now.
Old Nov 26, 2014 | 06:07 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
When i ran stock lifters, they were stock gm ls7 lifters. I ran them just fine in 230 deg cams at .600" lift but really it comes down to spring pressures.
I switched to morel link bars when i went 246 deg .640" hyd roller that required 180- ish lbs seat pressure and 450 lbs open. Thats getting to be high for a gm lifter. Gm ls7 lifters are better than pre 97 lifters. They have better valving internally and are good for most applications.
Old Nov 26, 2014 | 06:41 AM
Check with Chris Straub http://www.straubtechnologies.com/ he knows the stats on those OEM lifters and what they are good for.
Basing all our info on just one engine is not as good as a shop that has seen what happens when you exceed the limits of OEM lifters. I wish I kept track of all the calls and emails about OEM lifter failures. Chris will confirm what I am saying.
Old Nov 26, 2014 | 08:43 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Orr, do you have a PRO block, or just SHP?
Old Nov 26, 2014 | 09:28 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
That is correct but i was told from chris straub that pressure and rpm start to become a concern on oem lifters. Key word is exceed limits as you stated. He convinced me to go morel and my cam guy also suggested that they would be a good idea. My build was on the edge of comfort zone.
That being said i am not basing this on just one engine lol i am deeply rooted in the car scene in my town and know all the shops. havent seen one lifter failure with the new ls lifters used. There are dozens and dozens of cammed cars around here with no issue. Cams arent crazy and spring pressures arent super high so they do live well. IF you dont push the limits.
Old Nov 26, 2014 | 09:32 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Shp base block machined by Hinkson Auto above. Beat on for years, torn down to inspect and it was all fine. I didnt need to refreshen but wanted to openup ring gap more for the high boost i now run.
I highly recommend a block from Carl
Old Nov 26, 2014 | 10:55 AM
Justin you have been on the edge for a long time and I love it!!!!
Old Nov 26, 2014 | 10:58 AM
Any one building a 3.750 stroke or smaller I would recommend the Pro Block with a stroker rod like a Callies, Crower, Scat, Oliver ETC there is plenty of cam to rid clearance.
Old Nov 26, 2014 | 10:15 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
So for a 4.155 bore x 3.875 stroke you would recommend a pro block?
Old Nov 27, 2014 | 07:35 AM
If you were going to use a Honda journal rods or the Callies Ultra HD 2.100 rods you can use the 2.100 Callies Compstar rods but will have to use a reduced base circle cam.
Here is a build I did last year.
http://www.chevelles.com/forums/showthread.php?t=481081
Old Nov 27, 2014 | 03:03 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Those hd rods are nice but to expensive for na street builds imo. Either block would be nice, just depends how crazy you get with your build
Old Nov 27, 2014 | 05:12 PM
I have some of them running street and strip no problems, Some guys don't like running small base circle cams.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
mfp189
Sep 27, 2015 09:25 AM
