camshaft thrust plate
Old Nov 22, 2014 | 03:06 PM
indygene's Avatar
Car: 1982 Chevrolet Camaro Indy Pace Car
hello folks i have a1982 camaro with the 305 crossfire i am rebuilding the engine and need to know what is used to keep the camshaft seated in the engine block as the block doesnt have bolt holes to mount a thrust plate
Old Nov 22, 2014 | 05:09 PM
Re: camshaft thrust plate
Nothing.
The oil pump puts enough load on the distributor gear to hold it in. There's a SLIGHT (emphasis on SLIGHT) angle on the lobes, that helps.
Old Nov 23, 2014 | 12:13 AM
Night rider327's Avatar
Car: 1988 Camaro
Yep what Sofa said.
All flat tappet cams in the SBC/BBC uses no retaining plate/button. The angle of the cam lobe, lifter riding on lobe and the oil pump shaft/dist. gear/cam gear engagement holds the cam in place.
Roller cam engines on the other hand do not have the angle to the cam lobes and lifter don't sit on the lobe, just the wheel rolls on it, so they need a retainer of some sorts like a cam button, thrust plate, etc.
Old Nov 23, 2014 | 01:35 PM
indygene's Avatar
thanks for the info it is a great help
Old Nov 23, 2014 | 01:36 PM
indygene's Avatar
thanks the info is a great help
Old Nov 28, 2014 | 05:50 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Nothing.
You've gotten nicer. Used to be, you'd only put 'Nothing.'... or was that me? Damnit.
Old Nov 30, 2014 | 08:15 PM
Yes.
loud91rs
Oct 5, 2015 10:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
