Stumbling/bucking in lower rpm acceleration
Old Dec 3, 2014 | 07:39 PM
my87_5spgta's Avatar
I have a 87 5speed GTA. Out of nowhere car starts to stumble/bucking at the start of 2nd gear. 1st gear is fine a soon as i go into 2nd it stumbles/bucking hard till i get to a higher rpm and once i start to come back down in rpm to a idle and stop it wants to stall and sometimes does. Any idea what is wrong?
Old Dec 3, 2014 | 08:19 PM
1991camaro1996's Avatar
Car: 1991 camaro
Engine: 305tbi, 350tbi to come
Transmission: t5
Re: Stumbling/bucking in lower rpm acceleration
I would lean towards some sort of ignition issue - cracked/defective dist. cap, bad wires, or spark plugs. If not that, I'd check your fuel pressure.
Old Dec 3, 2014 | 08:22 PM
Its all new...and fuel pressure is over 30 psi
Old Dec 3, 2014 | 09:13 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
but how much FLOW do you have? flow is as important as pressure
Prodigious
Oct 4, 2015 11:20 PM
BewleyBizzIROC
Sep 7, 2015 08:05 PM
someone972
Aug 30, 2015 12:52 AM
jbd1969
Aug 17, 2015 07:06 PM
perZ
Aug 15, 2015 01:17 PM
