What is this thing I broke? (Pics)
I believe it was under the distributor. I seem to have broken off one of the plastic hoses and I can't remove it. What is this so I can order a new one?
Engine: 4++,350 & 305 CIs
Re: What is this thing I broke? (Pics)
EGR solinoid
The lines will come out and the 2 hole 90deg connector will come off.
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
I have never tried to remove those plastic lines from the rubber elbow. I've always just removed the rubber elbow/block from the solenoid.
As for repairing the broken line, my fix has been to get a piece of vacuum hose that fits TIGHLY to the plastic line and splice it back together. At that size, the vacuum hoses come in 1/32" increments. So, if 1/8" is too tight and 1/4" is too loose, you have choice of 5/32, 3/16, and 7/32 to get the perfect fit.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
replacement hard vacuum line can be had at AZ and the like. with a little heat it can be bent into shape to replace your broken pieces, just ensure that the heat and bending do not close it off.
The old plastic will come out of the rubber connector. If it's broken off flush, screw an appropriately sized screw into the hard plastic line to get a grip on it to pull it loose.
AZ = AutoZone
Car: 1988 Camaro
AZ =Auto Zone parts store..
Auto zone, advance auto parts, pep boys, napa, car quest, etc etc
lt1z350
Sep 29, 2015 01:50 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
