vortec heads
Old Jan 16, 2015 | 12:13 AM
  #51
Night rider327's Avatar
Car: 1988 Camaro
Re: vortec heads
Originally Posted by skinny z
Just so we are all on the same page and in case anyone reads this 10 years from now, the Vortec head (as originally provided by GM in the mid 90's) did one thing really well. It provided low and mid lift numbers that far exceeded anything that was available at the time. I'll stress again low and mid lift because that's what made them such a good cylinder head.
Not to mention all of that from a 170cc runner!
Great for port speed.
I said it already and I'll say it again.. Vortecs are the BEST budget head for mild/med power levels.
They are not a race head, they are not 7,000 rpm heads, they are not the best head out there, but like whats been said you can't beat them for the price.
IMO.. If you buy a set, have the guides milled down, spring pockets cut, port work done, screw in studs added, etc etc... You are wasting your money with the vortecs... They are budget heads.
Get em', stick with low lift cams, or do the ghetto grind, spend 40 bucks on springs, par them with the right compression and cam and you have a 375-415 HP engine with heads that you can get for $100-300 and $50 in mods to them, and $150 intake
Old Jan 16, 2015 | 12:38 AM
  #52
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: vortec heads
This post pretty much nails it on the head. I agree fully.
Old Jan 16, 2015 | 07:29 AM
  #53
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: vortec heads
Originally Posted by redneckjoe
GM shoulda used vortec heads with TPI on 4x4 mud trucks. woulda made a mean-azz low end torque motor.
anybody think the vortec intake port led to the development of the LS/cathederal port? just an old rumor?
kinda seems like "some" vortecs have as bad a reputation as the old "882's" for cracking. what the,.....?
You have to watch for cracking on just about any thin cast small block head.
As for the TPI comment, I had one on my old G20 van with Vortecs. Ran well, but I like the GM Marine L31 intake manifold better. It has shorter runners and has great low-midrange grunt.
Old Jan 16, 2015 | 11:24 AM
  #54
skinny z's Avatar
Re: vortec heads
Wow. We sure have a lot to say about the 'ol Vortecs.
Now here's a scenario for you. Opinions please.
I have a set of Vortecs that I purchased new about 10 years ago. (Not sure if they're the suspect Mexican castings or not)Used them box stock with an old single pattern cam. Short duration (less than 224) and .454 lift. Cranking pressure was 200+. Then upgraded the heads: screw-in studs, guide plates, Comp 26918 Beehive springs, enlarged push rod holes and paired it with a XR276HR cam and 1.6 rockers. Eventually, the heads were retired as they needed guides.
Here's my question and please remember my comments about "sunk cost". Do you invest the money in new guides? Maybe touch up the bowls a little? Or sell them as is and recoup the money in hard parts (springs, studs, machine work). For what it's worth, I've since moved past the Vortecs and said cam but that's another story.
I have the option to resurrect another 355 and re-use the heads and cam. No deadline.
While I'm at it, the same question could be applied to my currently in use RHS iron heads. They need guides too.
Old Jan 16, 2015 | 12:27 PM
  #55
Car: 1988 Camaro
Re: vortec heads
Skinny,
My opinion on that is.. Pull the rockers, springs, studs, guide plates off the vortec heads.. Then sell the heads for $300-400 (somebody will pay that for the stripped down, upgraded/modded vortecs)
Put that money towards much better bare alum. heads, buy a valve set from competition products for alittle over $100 and put all of the parts you pulled from the vortecs onto the new heads.
Old Jan 17, 2015 | 11:05 AM
  #56
skinny z's Avatar
Re: vortec heads
Hey Night
Pretty much my thoughts however....here's the deal. I have a decent of heads with the RHS I picked up a couple of years back. More than enough to build an engine that could potentially make north of 450 hp (realistically and more) although at the moment I have a pretty tame engine program (274/280 adv cam). So, the need for another set of heads really isn't there. For now anyway.
Is there an interest in the Vortecs with all of the good stuff already done yet in need of guides? (I suppose theheads could be used as is but I know they have a lot if miles on them).
Just kind of throwing this out there.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
