How in the heck does an aftermarket radiator stay secured?
Old Jan 8, 2015 | 10:47 PM
nakota2k's Avatar
Car: 1989 Iroc-Z 350
I bought a summit racing radiator and don't see how it would stay secured in the radiator tray. Are there brackets I need to buy or something or does it just sit there?
Old Jan 8, 2015 | 10:54 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: How in the heck does an aftermarket radiator stay secured?
Unless it is a direct fit you would need to make a new upper radiator mount/shroud/cover. If you have access to a metal brake you can easily make one. The radiator never sees any force that would cause it to move (other than airflow) so it doesn't need to be bolted down four different directions, just a bracket or two over the top that keeps it from moving up/down and side to side.
Old Jan 8, 2015 | 11:14 PM
nakota2k's Avatar
I bought this one, says it's "performance fit".
http://www.summitracing.com/parts/su...t/model/camaro
Can you link me to this metal bracket you speak of please.
Old Jan 9, 2015 | 12:15 AM
Night rider327's Avatar
Car: 1988 Camaro
I used 2 pc. of metal plumbers strap. I installed mine in 2005, and it's been bolted in and used like that with the plumbers strap ever since.
Here's 3 pics of mine. Excuse the dirty core support and lack of plastic try in a couple, I was working on car at those times
Attached Thumbnails How in the heck does an aftermarket radiator stay secured?-picture-408.jpg   How in the heck does an aftermarket radiator stay secured?-picture-587.jpg   How in the heck does an aftermarket radiator stay secured?-dscf3430.jpg
Old Jan 9, 2015 | 09:09 AM
nakota2k's Avatar
Oh that is in-genius. I believe mine actually fits under that lip, is yours over sized? Do you just have rubber bumpers on the bottom?
Old Jan 9, 2015 | 01:24 PM
Car: 1988 Camaro
Mine's over sized. Summit house brand, 31" wide x 19" tall x 3 1/8" thick, two 1" cores. I needed all the cooling I could get with my engine setup.
On the engine side of rad. I have a ford 2 speed elec. fan mounted on the rad with plumber's strap.
Then my transmission coolers are out front (on nose side) of rad.
Attached Thumbnails How in the heck does an aftermarket radiator stay secured?-picture-406.jpg   How in the heck does an aftermarket radiator stay secured?-picture-410.jpg   How in the heck does an aftermarket radiator stay secured?-picture-412.jpg
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
Stryker412
Sep 20, 2015 06:59 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
