A tapping in the FPR, what does it all mean?
Car: 92 Formula WS6, T-top
Engine: 5.7L T.P.I.
Axle/Gears: Limited slip, 3.23 10 bolt
I've noticed a tapping sound in my engine (1992 Formula L98). At first I thought it was a noisy lifter, but no. The sound is not coming from the valve cover, it's in the fuel rail. More specifically, it's in the FPR. The stethoscope really reveals it, but you can hear it clearly when the car idles, especially inside the cabin. There's the light tapping of the injectors, but this is a louder, heavier tap in the FPR. How normal is this, and what does it mean? I don't remember my other L98 I had years ago doing that. Fuel pressure is 35 with vacuum, 45 without.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: A tapping in the FPR, what does it all mean?
Engine: 5.7L T.P.I.
Hmmmm, I'd hate to have to drop the fuel tank to work on something like that. I don't have a lift, and have never done it before. Seems like it would be a pain. So then if what you say is right, would I hear the sound along the fuel lines on the way up the chassis? If it's there too, or is even louder toward the back, then it might be coming from the FP area. The fp is a little noisy, you can hear it wind up and wind down when you start the car or turn it off. Crap, man I really don't want to have to mess with dropping the tank...... I'll let it go as long as I can if this is what it is.
Engine: 5.7L T.P.I.
But I don't know. The more I think about that sound the more I'm not sure it could resonate all the way from the back of the car. It's really loud right at the FPR, and I've never heard it at the back. When I put the stethoscope on the FPR it really did sound like the sorce. There is a slight smell of gas in the FPR vacuum connector when I pull it off the regulator nozzle too. You could be right, but I'll have to check around some more.
Car: 86 IROC
Engine: 5.0 TPI
Engine: 5.7L T.P.I.
FP is 35 with vacuum, 45 without, so it's still in tolerances. But my thought exactly about the diaphragm, I'd bet it's OE. While we're talking about it, do you need a special tool to take the FPR cover off? I noticed its small hex bolts, but there's a small button in the middle of the bolt head. You know the one....seems like I read you need a special wrench?
Car: 86 IROC
Engine: 5.0 TPI
dimented24x7
Sep 6, 2015 03:51 PM
