Removing Power Steering Pump
Old Jan 12, 2015 | 09:00 AM
brian schuetta's Avatar
Car: 83' Camaro, 88' TPI 350 Firebird
Engine: 383
Transmission: th350
Axle/Gears: 12 bolt w/ 5.13s or 4.56s
Anyone ever pull a power steering pump off a TPI engine before? Just looking at it and don't see a obvious way to remove it from the bracket. Car is an 88' Firebird. Didn't find anything on-line that really helped.
Old Jan 12, 2015 | 09:19 AM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Re: Removing Power Steering Pump
I believe the mounting bolts are behind the pulley......
Old Jan 12, 2015 | 09:39 AM
Engine: 383
Transmission: th350
So remove the pulley then remove the pump?
Old Jan 12, 2015 | 09:47 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
nah you don't have to go that far. there are a number of bolts but the hardest ones are on the back of the pump. it can be done with common hand tools. just get a light on it and it will reveal itself
Old Jan 12, 2015 | 09:56 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
removing the pulley makes is easier but you need the right removal tool.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
Bull86
Aug 10, 2015 05:43 PM
3rdgenparts
Aug 8, 2015 07:09 PM
