89 305 tpi firebird hose
Old Jan 14, 2015 | 09:54 PM
shadaw009's Avatar
Car: Firebird Formula
Engine: 305 MFI
( 89 firebird formula 305 MFI) I replaced my fuel injectors because i have a warm idle issue but while replacing them i broke the passenger crankcase ventilation hose and have not been able to find a new one or a way to make one, any help would be great!!!! (In the picture it is the hose labeled "CCV")
Attached Thumbnails 89 305 tpi firebird hose-1987-89-5.0-5.7l
Old Jan 14, 2015 | 11:03 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 89 305 tpi firebird hose
You have to use 2 different sizes of hose and a connector. or find a NOS part
Old Jan 15, 2015 | 07:23 AM
shadaw009's Avatar
Engine: 305 MFI
Do you know what size connector because I've been looking for 3/8 to 1/2 and have found nothing, maybe I measured wrong ?
Old Jan 15, 2015 | 12:09 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
The P/N for that hose is, 10105290 and I can't find anything or anywhere on it.The P/N may have changed but they usually give you the New P/N.Your most likely going to have to make one or pic one up from the "Parts For Sale" Threads
Old Jan 15, 2015 | 02:02 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Get a length of vacuum hose that size. Stick a straight piece of TIG welding rod (Stainless) through it, now use your old hose as a guide and bend the new hose with the correct bends in it.
Old Jan 19, 2015 | 10:04 PM
mantaguy's Avatar
Engine: 5.0 EFI
On my 86 that part is Metal, maybe aluminum, with small hoses at each end.
Old Jan 20, 2015 | 12:01 AM
TTOP350's Avatar
They changed it in 88 (i think) to a 1 piece rubber hose, less leaks over time
armybyrd
Dec 5, 2015 09:22 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
