1990 iroc won't crank or start while cold
Old Feb 12, 2015 | 10:06 AM
Gary2424's Avatar
Hey guys my iroc hasn't been starting or cranking or starting in the morning when it's cold I have a brand new starter in it and the battery is good and charged I checked however one bit of information recently I bought and installed a VATS bypass module for it and it worked we hooked it up right and all however it seems the car won't crank when cold do u guys have any clue wtf is going on cause I'm at my wits end
Old Feb 12, 2015 | 10:19 AM
MightyMouse84's Avatar
Car: 1984 Firebird Trans Am
Engine: l69
Transmission: World Class T-5
Axle/Gears: Factory Rear End with 3.73(?) ratio
Re: 1990 iroc won't crank or start while cold
Have you tried replacing the battery cables and cleaning all of your grounds? I've had problems with SBC's not wanting to start when hot, but not when they're cold.
Old Feb 12, 2015 | 11:32 AM
Gary2424's Avatar
Yes I cleaned all if the battery connections and even put in another battery one that we fully charged just to be safe still nothing
Old Feb 12, 2015 | 01:32 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Does it crank?
Do you have power inside the car currently?
Old Feb 12, 2015 | 03:59 PM
Gary2424's Avatar
No it doesn't do anything and yes I have power in the cab
Old Feb 12, 2015 | 05:10 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Then your fusable links are good. Should be a loose connection as already mentioned. Double check bat cables and that all starter wires are tight and on the correct terminal.
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
Tonyy_z
Aug 12, 2015 07:20 AM
mustangman65_79
Aug 11, 2015 03:17 PM
drathaar907
Aug 6, 2015 04:20 PM
