89 RS, no timing tabs??
Old Feb 17, 2015 | 03:28 PM
Lck119's Avatar
Car: 1989 RS
Engine: 2.8 V6
Is it supposed to be welded on? Or bolted on? Attached is a picture of where I thought it was supposed to sit. I can't properly set the timing without it!
picture: http://imgur.com/rg15ghO
Old Feb 17, 2015 | 07:48 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: 89 RS, no timing tabs??
I'm not sure what year , but the location of timing marks changed . look straight down (12 o'clock , behind water pump) at balancer . you should see a "O" , that is your timing tab . good luck ...
Old Feb 17, 2015 | 10:34 PM
Lck119's Avatar
Car: 1989 RS
Engine: 2.8 V6
I can't see anything there. My friend has an 89 too and his has the regular V timing tab. Was going to try unbolting his and putting it on mine just to set the timing but we couldn't get it off.
Old Feb 17, 2015 | 10:42 PM
Lck119's Avatar
Car: 1989 RS
Engine: 2.8 V6
It's driving fine, I set the timing by ear and test driving and its runs pretty well, I just can hear it pinging under heavy load and when the RPM's are high. Should I just retard it slightly and take it for a test drive?
Old Feb 18, 2015 | 09:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Looks like someone swapped either the engine or at least the timing cover. The reason I say this is that there is a crank sensor of some sort where a 2.8l RWD engine shouldn't have one.
This being the three-wire sensor that is mostly obscured by the balancer.
RBob.
Old Feb 18, 2015 | 11:45 AM
Lck119's Avatar
Car: 1989 RS
Engine: 2.8 V6
Engine is definitely the 2.8 but if someone swapped the timing cover that would explain why it looks different than my friends. I would guess that its not plugged in to anything? I'll take a look after school. And to fix the pinging under heavy load should I just retard by a couple degrees?
Old Feb 18, 2015 | 12:18 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Backing off the base timing will help with the pinging. Probably should be done as the 2.8l engines didn't run a knock detection/reporting set up.
RBob.
Old Feb 18, 2015 | 01:10 PM
Lck119's Avatar
Car: 1989 RS
Engine: 2.8 V6
thank you!
midge54
Dec 27, 2019 04:14 PM
armybyrd
Dec 5, 2015 09:22 AM
masonta
Aug 31, 2015 10:14 PM
91REDZ28VERT
Aug 18, 2015 10:16 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
