Motor mounts
Old Feb 21, 2015 | 06:56 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Motor mounts
Does anyone know where I can get a set of GM rubber mounts? I'd really like to stay away from poly and I've heard the aftermarket mounts are garbage. The engine is out, so I figure I may as well do them.
Old Feb 21, 2015 | 10:16 PM
couchmotors's Avatar
Car: 1991 camaro rs
Engine: 496 big block
Transmission: th400
Axle/Gears: stock rearend. 3.23
Re: Motor mounts
GM has not made these mounts in along time you might have difficulty finding GM made mounts. I got mine from Pepboys and there under a bigblock and are working fine.i dont like poly ether there to noisy and send to much residence noise through the car. I had a poly trans mount and it was loud inside my 99z28 there are some good.rubber mounts out there you just got to shop around.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
