fuel pump and injectors no go.
Old Mar 3, 2015 | 08:08 PM
camsuper88's Avatar
Car: 88 iroc-z camaro
Engine: 305 tbi
Axle/Gears: idk
88 305 TBI. i went to start my car to set the timing but it would not start. i looked and the injectors are not firing and the fuel pump wount run either. i tried un plugging the computer and disconnecting the battery. have any of you had this issue in the past?
Old Mar 3, 2015 | 11:47 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: fuel pump and injectors no go.
Check your fuses first.
Does it crank and crank and crank and not fire? Or does it try to fire over and kind of stumble but never actually start?
Old Mar 4, 2015 | 06:37 PM
camsuper88's Avatar
Engine: 305 tbi
Axle/Gears: idk
It cranks and all that but I don't hear the pump kick on and I don't see the injectors spray.
Old Mar 4, 2015 | 09:28 PM
camsuper88's Avatar
Engine: 305 tbi
Axle/Gears: idk
So I disconnected all my stuff and I had it back for a second. Then I checked the oil pressure switch and it was loose. Could this play a part?
Old Mar 4, 2015 | 09:36 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Um, yeah. Thats a safety switch that kills the motor when oil pressure drops to low.
9192camaro
16
Feb 3, 2019 12:21 AM
jklein337
Sep 19, 2018 06:23 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
