EFI on a carb'd motor???? Help!
Old Mar 6, 2015 | 09:33 AM
xaftmx's Avatar
Car: 1987 firebird 305 carbd
I bought a 87 firebird 305. I know there have been mods on it, old chrome on the engine, painted block, disk brakes in the rear and it ran. So I picked it up, been going through it, removed all the AIR systems, hoses, extra vacuum lines, AC and junk.
then replaced the intake with an Edelbrock polished, and a E performer carb. with a bunch of chrome and a repaint of the block. Im putting this together, fired it up, all went really well. went to adjust the timing and realized,, there is NO vacuum advance. it looks like it is an EFI distributor, 2 connectors going into it with 4 pins over to a 4 pin dual coil. can somebody take 2 seconds and tell me what I have here? should I leave it as is or change it out for a vac advan setup. and if so what else needs to be changed.
thanks!
Old Mar 6, 2015 | 09:56 AM
bwiencek's Avatar
Car: 1984 TA - 17k orig miles
Engine: 355
Axle/Gears: 3.44 Dana 44 performance rear
Re: EFI on a carb'd motor???? Help!
Sounds like a computer controlled distributor - since it sounds like you've gotten rid of most everything else that feeds the computer signals I'd just swap it out for an HEI with a vacuum advance can - and then you can also tune it to your engine's needs.
Old Mar 8, 2015 | 10:20 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Yes, Bwiencek is right.
You removed the computer controlled carb (most likely) and your current distributor is electronic. It WILL not run right without the CC Carb attached to it.
Your best bet is to either put the CC Qjet back on and hook up the O2 and other sensors or get rid of the electronic distributor and go old school.
Old Mar 9, 2015 | 04:07 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
thanks!
The 87s used the remote coil, TBI distributors with the Q-Jet.
lt500r55
Sep 1, 2021 01:30 PM
theshackle
Mar 5, 2017 06:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
beachrodder
Aug 25, 2015 08:05 AM
cstrobel65
Aug 15, 2015 10:19 AM
