Exhaust Manifolds
Old Mar 11, 2015 | 03:05 PM
85Irocbuild's Avatar
Car: 1988 Gray Iroc
Exhaust Manifolds
Hey all,
I'm about to put my rebuilt 305 back in the camaro. I just cleaned up the stock exhaust manifolds and put them on. However, I noticed that it's going to be a tight fit trying to reach the motor mounts and move the engine aound when putting the motor in the car. However, it also looks like its going to be difficult to reach all of the manifold bolts if I install the manifolds with the engine in the car. So what have you guys done? I tried doing a search, but most stuff that came up was about aftermarket headers, not the stock manifolds. Thanks!
Old Mar 11, 2015 | 04:23 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Re: Exhaust Manifolds
I put mine back in with the stock manifolds fully attached. It will always be a pain trying to get the motor mounts to line up, but I don't think the manifolds really got in the way with mine.
EDIT: I should also note that my car was up on jack stands so I was able to access the motor mounts fairly easily from underneath. If you don't have the car raised up you may have more clearance problems than I had.
Old Mar 11, 2015 | 06:10 PM
Car: 1988 Gray Iroc
sounds good, thanks!
Old Mar 14, 2015 | 11:50 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Originally Posted by 85Irocbuild
Hey all,
it is WAY easier to get the engine in with the manifolds off. as for getting the manifolds on, put the bolts in them first .then slide them into position and youre home
Old Mar 15, 2015 | 11:25 AM
southbaysd's Avatar
Car: 1990 Firebird Formula
Engine: 5.0 TPI
I was able to remove and replace manifolds with the engine in the car, however the passenger side was a PITA and had to remove many parts, including coolant lines, and even then I had to use lots of different sockets and wrenches to get to the rear bolts
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
