cooler line
Old Mar 19, 2015 | 01:38 AM
sgp0511's Avatar
Car: 1988 Firebird
cooler line
so was installing my radiator and i cross threaded the bottom transmission cooler line into the radiator.unscrewed and tried to connect line after i saw my mistake and now the line wont even try to start to go into female part of radiator. what are my options? i really dont want to get a new radiator because of this
Old Mar 19, 2015 | 09:21 AM
southbaysd's Avatar
Car: 1990 Firebird Formula
Engine: 5.0 TPI
Re: cooler line
Figure out the size and type of thread of the connectors, maybe someone in the forum can help you with that, then get a tap & die set that includes this size and you will be able to re-thread the connector
Same thing happened to me with the A/C condenser and that's how i fixed it
Old Mar 19, 2015 | 01:39 PM
sgp0511's Avatar
Car: 1988 Firebird
Re: cooler line
Ok so does anyone know what size tap I need
Old Mar 19, 2015 | 06:47 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: cooler line
The problem with a tap is it won't go into the stripped fitting far enough to do any good.
The stripped fitting has a cone shape in the ID which mates to the flared tube end when the two are fit together and tightened.
Old Mar 20, 2015 | 07:53 PM
sgp0511's Avatar
Car: 1988 Firebird
Re: cooler line
I just need to get the first thread good because all the other threads look good just the first row thread looks messed up the reason the fitting wont even start
Bubbajones_ya
Jul 6, 2024 08:32 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
tommy z-28
Oct 6, 2015 10:58 PM
TBRays98
Sep 6, 2015 05:05 PM
apie2546
Sep 5, 2015 07:40 PM
