random sputter. have video
Old Mar 23, 2015 | 02:59 PM
amshnock's Avatar
Hello I have a 88 iroc with 350 TBI. Did the 350 swap some time back an my fuel pump went so I replaced it still have this sputter.
Some times the car stalls when stoped. But starts right back up.
In the video you will see every thing on my cluster be out of wack it needs to be replaced.
Anyways I tried messing with timing new hotter plugs everything. Im lost.
Have a look at the video an maybe you can tell me.
I like to add that it was a cold start.
Old Mar 28, 2015 | 10:41 AM
amshnock's Avatar
Re: random sputter. have video
I'm going to look everything over while I'm off this weekend . would be nice to know what it is
OK I messed with the timing some now I can drive with out stalling at lights but it still sputters an idle drops some then kicks back up. Kinda like I have a big cam in it .the cam that's in it is just a little bigger the stock. Also at high rpms it will stark knock.
Old Apr 1, 2015 | 07:34 PM
mcafee89formula's Avatar
Car: 89 formula 350 T-Tops
Engine: tpi 5.7 soon twin turbo 5.3
Transmission: 700R4 soon 4L80E
Axle/Gears: 323 soon 373 or 410 can't decide
It's just an L98 thing. Mine had done that since day one. I ripped it out and threw a 5.3 with a 4L80E and a twin turbo kit. Problem solved. Totally different car. Can't even describe the power. Rip it out
Old Apr 1, 2015 | 09:06 PM
amshnock's Avatar
I just dropped it in. If I do replace the motor it will be for a 400. Anyways I don't mind the sputter I mind the stalling then its hard to start starts like I have a big *** cam. But it I let it cool for a min it starts right up. Like I said it has no power loss but the spark knock but I think I know what that was.
As you can see in the video the motor runs good no tapping or knocking just the air pumb witch I'm going to pull soon.
I can only work on it on the weekends. So this weekend I'm going to pull the TBI an rebuild it again an clean my injector's.
Also I know there is no vac leak that was the 1st thing I thought an checked.
I just need it to run for a few months then I'm changing to carb.
I will upload a new video this weekend of it running to temp
Old Apr 5, 2015 | 06:21 PM
amshnock's Avatar
OK update I messed with the timing some more an cleaned all the connections
Here is a new video. I ran the car hard for an hour burn outs, power brake , high revs
350 TBI after running for 1 hour:
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Luigytico09
Oct 1, 2015 08:46 AM
