Please help with MAF sensor
Old Mar 24, 2015 | 03:00 PM
Lck119's Avatar
Car: 1989 RS
Engine: 2.8 V6
I've owned the car for 6 months. It came with a bad reman MAF. I replaced it with another reman MAF. Three months later that one went bad too. I told the parts store I didn't want a reman one this time because they all seem to break so they ordered in a new one. Turns out it wasn't new and it was another reman one. I took it because I needed to drive the car and I knew it had a 1 year warranty on it. Now a couple months later it has gone bad again. The only place in Canada that could get me a new one was GM so I have ordered one from them. My question is, do I have an electrical problem that could be causing these MAF's to go bad, or is it simply because they are reman parts?
I'm wiling to spend the $350 from GM just to fix this once and for all but I'm worried that if I have a problem this brand new one will end up fried as well.
Any thoughts are appreciated! Thank you
1989 2.8 T5
Old Mar 24, 2015 | 05:08 PM
Cosmik Debris's Avatar
Re: Please help with MAF sensor
There was another similar thread to this about failing MAFs. You could have an electrical problem, the voltage regulator or some spiking on the electrical system. Apparently from the other thread some cheaper MAFs are not reliable. To be sure buy a GM, I think they are made by AC Delco, I have used them before and they seem to be just fine.
BumpaD82
Feb 26, 2016 02:57 PM
sleprock
Oct 1, 2015 09:39 AM
Racerx974
Sep 19, 2015 10:16 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
earlpote
Sep 12, 2015 11:55 AM
