x24 Vortec timing Cover on 2pc RMS 400 motor
Old Mar 24, 2015 | 06:07 PM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Hi Guys,
One of the latest gremlins I've found I want to eliminate before all my motor and car go back together is the timing cover for the motor.
I'm doing a x24 conversion and bought the plastic vortec timing cover to cut down on costs.
I had heard this won't fit exactly and can leak but a good bead of sealant will fix that.
What I didn't know is someone mentioned the 2pcRMS motors need the timing cover to match - Is this fact or fiction?
I was under the assumption the 2pc RMS only affected the *** end of the motor and the sump.
Will I have a problem with this, or is it a non-issue?
Old Mar 24, 2015 | 06:52 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: x24 Vortec timing Cover on 2pc RMS 400 motor
No, that is just not true.
The timing cover for a gen 1 small block will fit 1955 to 1995 SBC engines. No diff in the cover for a 2 or 1 pc RMS engine.
Old Mar 24, 2015 | 06:57 PM
evilstuie's Avatar
Thanks for that.
One less problem
Old Mar 24, 2015 | 07:32 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Vortec cover has built in dowels for the block. Sbc non vortec blocks have dowels. So have to remove the block dowels or drill out the plastic timing cover dowels. Thats what i did i drilled the vortec cover.
Just use Rightstuff around alll of it and the dowels. It will seal good
Old Mar 24, 2015 | 07:42 PM
evilstuie's Avatar
Sounds like a plan.
Thanks for that.
Just received my AVT-852 cable today, so I'm gonna make a benchtest cable with one of the 0411 pigtails and start looking into the tuning side, or at least the config for my setup.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
MustangBeater20
Oct 29, 2022 09:20 PM
camaro71633
Sep 1, 2015 10:24 AM
mustangman65_79
Aug 8, 2015 01:18 AM
