CAMM crane cam 2032 good choice? on 5.0 305
Old Mar 25, 2015 | 05:07 PM
88iroc562's Avatar
Car: 88 iroc z. convertible
Engine: 5.0. 305
Transmission: automatic
Hey, guys I haver a perfect stock 88 iroc convertible down to the muffler and catts. first off am getting a Flowmaster and some headers put on this weekend but my valve seals are gone, every time I turn it on when its cold, the exhaust throws white smoke big time. so since I'm fixing that in putting a cam I was thinking the crane cam 2032 plus this is the highest I can go whit out a tune any suggestions
thanks guys
Old Apr 1, 2015 | 12:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Should be fine.
You should replace the valve springs while you're at it.
Old Apr 1, 2015 | 06:18 PM
2005Impalla's Avatar
Car: 86 Z28 T-Top
Engine: Vortec 350
Axle/Gears: I think 3.73 open dif
Re: CAMM crane cam 2032 good choice? on 5.0 305
Looks like a good choice. Always run new springs when swapping out a factory cam for an aftermarket one. Post a sound clip after you install it, should sound nice.
Old May 19, 2015 | 11:48 AM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
I have a 2032 sitting on the shelf for my 5.0 as well. I'd recommend replacing the springs as well. I went with the Comp Cams 981-16, only $64 through Summit. Hoping to get it installed sometime this summer. If you go through with it, let us know your final thoughts!
Old May 19, 2015 | 12:32 PM
88iroc562's Avatar
Engine: 5.0. 305
I will, I just got a hold of a ls2 back home in California but still doing the cam swap because the tune port motor will be a sand rail motor eventually and the iroc will have a new ls2 hart hopefully I can back it up whit a t56 soon
Old May 20, 2015 | 07:26 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
you need an afpr and use the springs crane recommends. not only that what lift can the heads support?
i like the cam...
Old May 20, 2015 | 08:32 AM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
does he need roller lifters for that cam?
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
colton_carlson
Mar 8, 2019 12:21 PM
Wvcamaro
Sep 4, 2015 08:38 PM
camaro71633
Sep 1, 2015 10:24 AM
