need NSS help
Car: 1988 iroc
Engine: 350 tpi
Transmission: 700 R4
Axle/Gears: 2.77 G80
need NSS help
I have an 88 iroc, no vats and the car starts fine. After driving it won't start till an hour or so. I put a test light on the NSS yellow wire and the purple wire going to the starter and I have power. I test it at the starter and no power, my understanding is the wire is straight to the starter. Is there a relay between the two or something I'm missing? Any help would be greatly appreciated.
Transmission: T-5, TH350, T-5
Re: need NSS help
There's a starter solenoid between there. I think they are all behind the D/S kick panel. I maybe wrong about location so you may have to trace he wires... http://austinthirdgen.org/mkportal/m..._continued.gif
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: need NSS help
the starter solenoid is attached to the starter, your solenoid is probably worn out / overheating
Sorry not solenoid, starter relay is in the d/s kick panel.
Re: need NSS help
Now since you have no relay , and are sure you have +12V on the purple wire coming from the NSS , but not at the starter , there are really only two possibilities .
#1 ; That there is the remnants of an old alarm system tucked away hidden under the dash someplace , and it's inhibiting your start signal from getting to the starter ,
Or ,
#2 ; That the body connector next to the brake booster that carries the wires to and from the dash , has developed a corroded , sometimes making and sometimes not , connection that is inhibiting the +12 from getting from the NSS to the starter . If there is no old alarm , and your sure of that 100% , I'd be checking that body connector and see what ya come up with there .....
Or ,
Car: 1988 iroc
Engine: 350 tpi
Re: need NSS help
OK I double checked and there is 12 v, drove the car for about 30 min and it won't start back, rechecked and the wire at the starter is dead. I'll check the body connector. Is something I can get to under the hood or should I go under the dash. I got the car new so no alarm has ever been on it... And thanks for the replys, these wires is becoming a headache
