tpi intake probs
Old Mar 27, 2015 | 11:19 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
tpi intake probs
So, I am building a 350 for my 86 using some procomp? 190cc aluminum heads, I finally got to installing the intake using fel-pro gaskets and the intake doesn't even cover the intake runners in the head! I only have a phone so hard to get pics on a forum, would an aftermarket intake work or am I SOL?
Old Mar 28, 2015 | 08:44 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: tpi intake probs
You didn't state what gaskets your using 1206 ? , you can have aluminum welded to the intake . Then open up the intake port / raise the roof.
Old Mar 28, 2015 | 08:51 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Here's a thread on gasket/port sizes.
Use the details from the #5 money post by jbc999 to determine how big your head ports are, and what your options become. An aftermarket/SuperRam/BigMouth base might be required. But then, I think you've already figured that out with the "intake doesn't cover the head ports".
375-1256 Port Size: 1.23 x 1.99'' Stock with open exhaust crossover
375-1204 Port Size: 1.23 x 1.99'' Stock with blocked exhaust crossover
375-1205 Port Size: 1.28 x 2.09'' Stock or small race port
375-1206 Port Size: 1.34 x 2.21'' Medium race port
375-1207 Port Size: 1.38 x 2.28'' Large race port
PS. You should not try to port a tpi base to anything larger than a 1204. You should consider a superram base if you want to go to a 1205.
1992rs/ss
Jan 31, 2025 05:10 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
