HELP! turns over but won't catch
Old Apr 19, 2015 | 11:46 AM
dibella989's Avatar
Car: 1988 Trans Am GTA
Transmission: 5-Speed
Axle/Gears: 3:45
1988 trans am gta with tpi. Was letting it sit to warm up but it stalled and sat there for a minute. when I went to go start it, it turns over but wouldn't start. I thought the engine might be flooded so I let it shut for awhile and tried again. Still nothing. Now it sat over night and tried it once more, still nothing. Tried jumping it as well, still nothing. Is it just really flooded or is it something worse? What should I do?
Old Apr 19, 2015 | 12:23 PM
dibella989's Avatar
Axle/Gears: 3:45
Re: HELP! turns over but won't catch
I think it could be the fuel pump, or possibly even just the filter.
Old Apr 19, 2015 | 09:13 PM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
yep, check fuel pressure, but first open the gas cap, and have someone turn the key to run while you have an ear to the open filler tube, if you dont hear the pump prime, i would start checking for power to the pump ... or you could just go get some starting fluid and see if it runs on that, if so it is a fuel problem ... also make sure the security light is going out after a few seconds (i would think it is, as it turns over)
Old Apr 20, 2015 | 06:49 AM
dibella989's Avatar
Axle/Gears: 3:45
Going to do that just to be sure, but I talked to the previous owner and he said he replaced the fuel pump, so I'm keeping my fingers crossed it's not that. I'm going to replace the filter later today and hopefully it just got clogged.
Prodigious
Nov 7, 2020 09:23 AM
Derick15
Sep 17, 2016 05:28 PM
L98GTA87
Aug 25, 2015 02:23 PM
ZsTransAm
Aug 11, 2015 07:30 PM
BrianI
Aug 9, 2015 11:52 AM
