Would you change the rear main seal?
Old May 9, 2015 | 05:45 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I'm doing the 700 to T5 swap. Initially when I puled the flywheel everything was fine. Seal was dry. One piece RMS. It wasn't until a few hours after I drooped the back of the engine that a drip started to form dead center of the seal. I don't like messing around with seals like that if they're is no reason too. Just wonder if the tilt is putting pressure against the seal. Then again, I guess that's no different then if the car were on a hill. It shouldn't leak then either. Correct me if I'm wrong, but the one piece seal is just plug an play? If I should replace it, it's just that round seal that pops out and back in? I don't have to drop the pan and pull out the aluminum retainer.
Old May 9, 2015 | 06:27 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Re: Would you change the rear main seal?
No more trouble it is to change out a one piece main seal, while the transmission is out, I would certainly change it.
customblackbird
Aug 15, 2021 10:16 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reborn756
Sep 4, 2015 03:42 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
