Is a Performance Distributor worth it?
Old May 9, 2015 | 11:30 PM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
I've got a rebuilt 355 with
Vortec heads
running the CCC
qjet with GMCOPO updated computer and prom
228/234 cam
Redline 5500-6000
Looking at a DUI Performance Dist kicking out 50,000..., I guess stock is 40,000?
So it's not too trick but slightly better than stock.....
In my case, is it worth it?
Chuck
https://performancedistributors.com/...-distributors/
Old May 10, 2015 | 01:04 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: Is a Performance Distributor worth it?
Really no. Not on a mid engine. Stock dist. with a good module and coil will do everything you need it to do. The best thing you can do is put good plug wires on it. Something with low ohm resistance. I like MSD 8.5mm 50 ohm per foot plug wires
Even the high end CD ign. systems (spark boxes) and billet dist., etc is not going to gain you anything on a mild engine. They do work and they work great IF your engine needs it. I.E large duration cam, high idle speed, rich fuel tuning, high RPM use, etc
I ran down into the 11's on a pretty much stock HEI dist. in my camaro shifting at 6400 rpm. Now have that same setup in my V8 S10 with a 355, vortec heads, 10.24:1 compression, 214/224@.050" cam
Now on my camaro I have a better ign. system but have Brodix 200cc heads, 249/252@.050" cam, 10.38:1 compression, 1000-1100 rpm idle speed, shift at 7200/7300 rpm. I run a mallory 685 digital box. Mallory E core coil, MSD billet dist.
Old May 10, 2015 | 08:55 AM
Chuck84TA's Avatar
Thank you for that response!!
That is what I expected to hear.
I'm running 9.7/1 compression. Barely reaching 400 hp at he crank ..
Do you think that a perf dist helps the engine run smoother at all RPMs?
I think with my cam at 228/234 and still using my CCC Qjet with the Cliff Ruggles mods to the idle tubes (richer mix) .... It may benefit from a perf dist.
Old May 10, 2015 | 01:14 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I ran a large cap HEI for years. The advantage to an aftermarket distributor is that it's a little easier to adjust the spark curve. It can be done with any distributor but it's easier with an aftermarket one. The only thing I did to the large cap HEI was a new cap, rotor and aftermarket coil.
Even the stock HEI module is better than an aftermarket module. It can easily provide enough spark up to at least 7000 rpm. The advantage of using an aftermarket ignition is the multi spark option. Instead of one large spark to ignite the fuel, there are multiple sparks in that short period of time.
In reality, you really don't need an aftermarket distributor unless your stock one is worn out. Bushings and parts do wear out over all the years of use which can cause all sorts of ignition problems that you would never even notice until a new distributor is installed.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jlanz55
Sep 9, 2015 09:09 AM
Gunsbee
Sep 7, 2015 07:10 PM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
