ID 350 1pc RMS and 2pc RMS
Old May 11, 2015 | 07:48 PM
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
Crazy question?
but can i tell if a sbc 350 is a 1 pc rms with out removing trans? any thing else to id the motor?
thanks for the information
Old May 11, 2015 | 08:06 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: ID 350 1pc RMS and 2pc RMS
Casting number always works.
Suffix code works too
If you can look under the engine you can kinda see. You will be able to see part of the 1pc rear seal "holder" and the two small studs that holds it to block
Old May 17, 2015 | 12:46 PM
Old May 17, 2015 | 06:57 PM
Drac0nic's Avatar
If the engine's got the intake pulled or you can sneak a look down in a pulled off valve cover if it has lifter bosses it's definitely a roller motor.
Old May 18, 2015 | 01:41 AM
Car: 1988 Camaro
True but not always a dead give away on 1pc vs. 2pc rms as the truck engines did not get roller cams until the vortec engine in '97
The casting number on the rear, top of trans bolt flange behind driver said head, suffix code on front pad in front of pass. side head and looking at the bottom back of crank it's self is the best ways of telling 1pc vs 2 pc.
I don't have the pictures but if you goggle sbc 1pc vs 2pc rear main seal crank I'm sure you will see pics showing the rear of both cranks and you will then for sure know the diff in looks. You can't miss it. One is a full circle (1pc seal) and the 2pc rear seal crank end has a round top, and notched and squared off on the bottom
89fast5oh
Sep 8, 2015 09:55 AM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
