Code 34, High Idle Running rough and rich. 88 305 TPI IROC.
Old May 22, 2015 | 12:24 PM
TysIROC's Avatar
Car: 1988 IROC Convertible
Transmission: 700 R4
Axle/Gears: 308:1
Hello all. After searching and trying some of the other troubleshooting ideas, I am open for suggestions. I have a 1988 IROC Convert, 305 TPI, 108000 miles, mostly stock. It has been running rich (Exhaust is rank) drives rough (Constantly adjusting pedal to get power) and throwing a code 34. MAF Voltages are pretty normal, .8V at 1200 RPM (The lowest I can get it), and 3.8V at 4500 RPM. TPS voltages also in spec. New plugs, wires, air filters etc. Runs great in cold weather, crappy in the summer. Fuel pressure good, timing is next to perfect with light. Very frustrated, any help or ideas appreciated. Add code 33 to the mix after it's run for a while.
Old May 22, 2015 | 02:27 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Code 34, High Idle Running rough and rich. 88 305 TPI IROC.
34-MAF issue
How is old is the O2 sensor? It's cheap, change it.
Have you performed the Min Air and TPS Set Procedure together at the same time? If not, start over and see this set procedure and follow it.
https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Old May 22, 2015 | 03:33 PM
TysIROC's Avatar
Axle/Gears: 308:1
I'll give that a shot. Air screw never tampered with, factory cover in place. I'll run through the procedure on both. Had the same though on the O2... So I changed it. Brand new. No difference.
Thanks.
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
