1991 trans am engine problems
Old Jun 1, 2015 | 03:13 PM
bswins82's Avatar
Car: 1991 Trans Am
Engine: 5.0
Hi. I just bought a 1991 trans am. drove great, i notice it would stutter some, so I did a tune up new plugs and wires. The today driving it around town it acted like there was no gas, once I put some in it. It ideal's fines but when giving gas it starts to spit and sputter then stalls out. its 5.0 V8
Old Jun 1, 2015 | 05:49 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: 1991 trans am engine problems
I'd start with checking the fuel pressure. If it's low then you have a starting point to determine if you have a bad regulator, clogged filter or faulty pump.
Old Jun 1, 2015 | 10:19 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Replace your fuel filter. Easy, cheap, and since you just bought the car you have no idea how old it is. That's where I'd start.
Old Jun 10, 2015 | 08:05 PM
bswins82's Avatar
Car: 1991 Trans Am
Engine: 5.0
I replaced the fuel filter it started great and ran. took it for a nice drive. then I let is sit for a hr to go back out to start it. Hard start for a second then once it started. If you gave it any gas from ideal it would want to stall and spit and sputter also there was grey smoke coming out of tail pipes
Old Jun 11, 2015 | 08:13 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Check if the OEM Multec injectors are still in the engine. If so replace them.
RBob.
Old Jun 11, 2015 | 09:20 AM
SR71BLKBRD's Avatar
Car: 92 Firebird, 91 GTA
Engine: 305 TBI, 350 TPI, * LS1 (Building)
is the check engine light on?? If so id recomend getting a code reaader. one of the best investments I made. you can alway check how muchpower the injectors are getting. one bad injector can make it run like crap. quick way to check is by unplugging the injector to see if its bad. just unplugging the one thats bad can make it run like normal. also could be the tps sensor on the throttlebody. when i purchased my 91 gta it would idle fine but when i tried to get on it it would fall flat on its face. swapped out the tps sensor and it ran fine.
Old Jun 11, 2015 | 11:39 AM
bswins82's Avatar
Car: 1991 Trans Am
Engine: 5.0
No check engine light. I have notice it pop on if I drive for long periord of time then shuts off. But only after I've been driving it for 30 mins or longer
jhawkeye
May 25, 2022 06:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
