89 2.8 idles high.
Old Jun 2, 2015 | 01:38 PM
Switch's Avatar
Car: 89 Camaro rs
Engine: 2.8 v6
Transmission: manual
Axle/Gears: rear wheel drive
89 2.8 idles high.
Hey guys I know there's alot of this here, but I haven't found one with a similar sympton.
So on my 89, it cranks fine starts up well, but sometimes idles at 2K on startup, and drops down to 1250 minimum during a stop at an intersection. Just interested in possibles of whats up with it. Anything helps, stock 2.8, only things I've done to the motor is a clutch job, replacing the starter, new rotor and plug cables.
Old Jun 2, 2015 | 03:58 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Re: 89 2.8 idles high.
This will help a lot https://www.thirdgen.org/forums/v6/595112-1988-camaro-2-8-a.html
Testing voltage on the tps is a great way to start
Old Jun 2, 2015 | 05:06 PM
Switch's Avatar
Car: 89 Camaro rs
Engine: 2.8 v6
Thanks much
Old Jun 17, 2015 | 12:20 PM
Switch's Avatar
Car: 89 Camaro rs
Engine: 2.8 v6
What should I be testing for the Tps. I can't find any mention of it in my repair manual. So obviously I haven't gotten far. I'm assuming the sensor is right next toish the throttle itself, but what should I be testing and what should the voltage be at that point?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Zane Story
Oct 8, 2015 12:40 PM
TrevinE
Sep 14, 2015 03:20 PM
IROCtometal
Sep 9, 2015 10:01 AM
rjcme
Sep 5, 2015 01:23 PM
