Smog reject - When 4 pin connector pulled from distributor car stalls
Old Jun 8, 2015 | 02:15 AM
KNIGHTE's Avatar
Car: 1985 TA http://bit.ly/1EadkbO
Engine: 5.0 V8 LG4 BBL
Transmission: 5 Speed Manual
Hi Guys,
My car is running fine, but the smog guy sent me back because he thinks there is a retard in the timing. I passed the EVAP test but when he pulled the 4 pin connector, the car stalled and he said it would not pass with bad timings.
I have no Check Engine lights and car seems to be running fine to me...
Do i need to get the timing set with a light or is it a minor adjustment i could do myself?
Old Jun 8, 2015 | 06:24 AM
Vader's Avatar
Re: Smog reject - When 4 pin connector pulled from distributor car stalls
The base timing should be set using a timing light. There should be a noticeable change in timing when the EST connector is removed or reconnected, but the engine should remain running in either case.
A good starting point for base timing on an unmodified LG4 is 4° BTDC for regular fuel. If cylinder head temperatures are kept lower due to modifications or the camshaft has been replaced with something providing greater duration the base timing may be set to accordingly to provide the advance necessary for best operation.
Old Jun 9, 2015 | 07:20 PM
project89's Avatar
the guy pulled the 4 pin connector on the base of the distributor not the est wire.
if im not mistaken the ignition ont fire without that plugged in
edit
sig says lg4 do u have the coil in cap or the small cap hei?
Old Jun 9, 2015 | 07:48 PM
BlueMagicSS's Avatar
Car: 2000 Camaro SS/86 Iroc/89 Iroc(x2)
Transmission: 6 Speed
Axle/Gears: 4.10
The 4 Pin Connector at the distributor shouldn't be unplugged. If it is the car will stall. What he should be looking for is the tan/black connector near the A/C box to disconnect to check timing.
-Matt
Old Jun 9, 2015 | 07:56 PM
Damon's Avatar
Wait, wait, wait. Vader's advice is absolutely correct IF WE ARE TALKING ABOUT A CARURETED LG4 305 ENGINE. I'm getting confused with KNIGHTE and project89 posting like they're the same guy with the same car.
IS THIS AN LG4 CARBURETED 305 ENGINE WE'RE TALKING ABOUT??
Old Jun 9, 2015 | 08:44 PM
KNIGHTE's Avatar
Yep LG4 carb and I believe the 4 pin wire is correct. There seems to be a problem with the harmonic balancer. They could not get it to set at 0.
Instead they found top dead center and set it manually or something. When they did this (and the mechanic tuned my carb to run a little leaner) I passed smog!
Yay!
Ghettobird52
Jul 5, 2024 11:18 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Wade787b
Sep 29, 2015 01:15 PM
mizz0313
Aug 12, 2015 06:45 AM
bryan623
Aug 10, 2015 11:33 AM
