Trouble starting, please help.
Old Jun 9, 2015 | 09:40 PM
Marauder82's Avatar
I bought a 86 camaro iroc with the 305 TPI for my 16 yr old son. Last Friday, the day he got his license, we started having troubles with it starting. Seems that the biggest issue is when the vehicle is warm the engine just rolls and won't start. I have checked everything that I can possibly think of from the plugs, ignition control module, battery, plug wires, electrical connection, fuel, injectors and fuel pump are brand new. I will be picking up a rebuilt mass air flow sensor tomorrow but I am stuck and cannot figure it out. Please give me some ideas on what I can look at, it would be very much appreciated.
Old Jun 10, 2015 | 09:59 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Re: Trouble starting, please help.
get some starter fluid. The next time it won't start spray it into the throttle body. If it starts check out your temperature sensor. If not, then perhaps you have a cracked ignition control module that only fails when it's hot enough.
Old Jun 11, 2015 | 10:35 AM
Marauder82's Avatar
Thanks I'll try that. I took the ICM out and had it checked, it passed all 7 tests they did on it.
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
armybyrd
Dec 5, 2015 09:22 AM
backtothe80s
Sep 5, 2015 12:39 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
